Animation problem
Animation problem
JHRendon
Animation problem
JHRendon
Recently I saw this happens to the view line, make those shorts movements. Anyone know if this is a bug or why is this happening?
Pradipio
Autodesk Support
Autodesk Support
Hi @JHRendon ,
Thank you for posting on the Fusion 360 forum.
this might be happening due to the Playhead, not in the correct position, if you do not want to add view orientation you can turn that OFF from Animation > View.
you can start with 0 sec, set your first view then set the Playhead for few seconds like 5 sec. and now change the view, then again set the play-head for few more seconds as required and change the view this will add the view for specified seconds.
I hope this will helps.
THANKS
Pradip Mistry
”Community
