Animate a full 360 rotation of my design for Render
Hi there, I am trying to animate a consistent animation of a fly-around of my assembly, but can't seem to get it to render the fly around.
Is this possible, I tried rotating my "camera" view, but you can't seem to keep this consistent so it looks jittery
Thank you
Duncan
jan.gladines
If a turntable is what you're after, you can follow this guide. Be aware that you first need to create a normal render before you can create a turntable.
http://docs.autodesk.com/ADSK360/help/ENU/rendering/index.html#!/url=./files/GUID-580C238E-BA22-4763...
Brady_Fulton
In the animation work space you can scroll down the timeline, then rotate your object 359 degrees.
This will animate a full spin.
If you need "rendered" quality on the materials and appearance though it wont meet your needs.
TrippyLighting
The turn table render options is only available when could rendering, not when rendering locally. It is also limited to a resolution of 36 frames per second so 10 degree steps. If that's enough for you then cloud rendering will do the job. If you want sooth, professional results then you need to use an external render option.
