angled plane issues
angled plane issues
narvi
angled plane issues
narvi
Hi! I have some troubles positioning the Angled plane.
When i create plane a t angle to Y axis, my point of origin of sketch is at 1.213 distance from global origin. And i don't see any way of fixing it. How i can position the angle plane so it's origin matches the global?
mike.tessier
Hi @narvi,
Thanks for posting and welcome to the Fusion 360 community!
I have come across this issue before in this forum post. The developers are still working on a fix at this time (it is logged as a defect, FUS-25516 for your reference). I have added a link to this forum post in the defect report in our system so the developers may be able to contact you directly.
For now, as a work around, you could project the origin into the active sketch plane, and then base your sketch geometry off of the projected global origin. The attached screencast shows how to do this.
Hope this helps!
Cheers,
Mike Tessier
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
