angle joint problems
im having a royal pain getting these parts to properly join .....could u please give me a hand
TrippyLighting
I am assuming that properly grounding the bn would likely be one of the problems, however, that is an assumption.
"royal pain" does not contain any detail as to what exactly he problem is.
Edit: I think I've found the actual problem you are having. That looks like a bug go me. The preview of the last rigid joint is OK, but when you click on OK it flips. The is unfortunately quite an old "thing".
@ryan.bales can you please check this out ?
sorry about the lack of info but im just not sure how to describe my problem.  I completely forgot to ground it ill do that now and ya that bug drives me nuts, ive had that happen before a few times
davebYYPCU
How I would do it....
Edit: Forgot the file,
wow thx
but how do u know what angle they need to be
davebYYPCU
Drew a sketch, measured the angle, and deleted the sketch, placed the angle in the Joint.
Might help....
