Angle issue on face...
Hi There.
I'm new to Fusion 360.
I want to make an 8 degree angle on the highlighted face. So that it tapers away from the centerline of the slot.
How do I do this??? I've tried using "Draft" without any luck. Also tried to put an "angle it when using "extrude", but it angles in the corners instead of across the whole flat/face.
Hope you can help me and get an idea of what I mean...
Photo attached.
Kind Regards, Jeppe Andersen
HughesTooling
You should be able to use Draft, turn the origin on first then select the correct vertical plane that's at right angles to the face you need to draft.
If you're still unable to angle the face can you share the part. Use Export on the file menu and save as an f3d file.
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks very much Mark.
Problem solved! Helped when I selected the origin and chose the correct plane!
Regards, Jeppe
