Angle body section outwards
karl.wernerJUNVH
karl.wernerJUNVH
Hello!
First, thank you for your help. I am creating a part that needs to sit flush to an existing item. After some trial and error I have come up with the shape you will see in the attached pictures but there is one problem. The 'tines' or 'legs' of this shape need to angle or twist outwards slightly at a certain point in the body and I'm not sure how you would use the loft (or another) command to do this.
To help further explain please see the embedded picture. The red arrows indicate the current geometry of this shape while the blue arrows indicate what I'd like to accomplish. I will also post the current fusion file. Again, thanks so much for helping.
TheCADWhisperer
@karl.wernerJUNVH
For some reason I cannot see an image in the Canvas?
Next thing I notice is that there are no dimensions (and numerous white dots) in Sketch1?
Then I Delete this curve and find that it is duplicated 3 times???
I do not understand the Design Intent?
Are you trying to reproduce something that already exists in the real world (or similar)?
If yes, do you have any pictures that you can share?
@karl.wernerJUNVH wrote:
... needs to sit flush to an existing item
