Alternative to using Sketch Blocks in Solidworks
I design tires and the logos can be fairly complex. normally i just break the sketch up into sketch blocks than align them to a circle. i cannot find a good way to do this in fusion without creating many sketches for one single logo.
Any suggestions would be greatly appreciated.
Jason
jeff_strater
Hi @Anonymous,
There is nothing like sketch blocks in Fusion today.  You can either do what you are already doing (create multiple sketches), or even go one step further, and create a component for each sketch block, each of which contains a sketch.  The advantage of using components is that they are easier to position precisely (with joints), and you can also create multiple instances of them efficiently.
Jeff
Jeff Strater
Engineering Director
