Alluminium Brushed Linear texture issue
MarcoAttal
MarcoAttal
Anyone have problem with these texture? they look ever black, I can't apply silver or change color.
In the MODEL workspace they look correct but when I switch to the RENDER workspace no more.
thanks
Phil.E
Sorry to hear this is a problem. Can you post an image of the render? Have you tried changing the lighting in your rendering?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
MarcoAttal
Here two screenshot of the same model, I have use emissive texture to have  more light source, but the issue is the same if I change the scene light of fusion, I have use in the past some time the Aluminum Brushed linear texture but I don't have had this problem previously.
The strange things are that in the model and in also in render workspace the texture looks correct but when i launch the rendering, the texture looks even dark/black sometimes with strange square reflex
michallach81
Again, it's caused by environment map that has dark places and they are reflected on glossy surface.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
michallach81
In a few minutes I will post a screencast.
Michał Lach
Designer
co-author
michallach81
Screencast below:
Michał Lach
Designer
co-author
MarcoAttal
Thanks, I have understand how to control that, thanks a lot!
