All external component assemblies - timeline history and component folders?
mrm1018
Message 1 of 24
mrm1018
When all external component assemblies (non-hybrid), is there a reason keep the timeline history active?
I have an assembly with 100's of fasteners...
Is it still possible to have an internal component in an assembly to behave as a folder for a bunch of components (fasteners) in the new intent-driven design workflow?
Replies (23)
Message 2 of 24
aleksei_ovsienko
Why would you want to do it? I'm not saying it's wrong, I just can't see the benefit. Is it just to arrange them tidily in the browser? How does it then impact the BOM extraction and data handling?
To be honest I keep thinking about the same. The more I try to use Fusion timeline in the assembly, the more I dislike it. The worst thing is that inserting a component and mating/joining it are two separate features that can easily wind up miles apart and the "Select referencing joints" feature is really elusive and doesn't at all work with constraints. The timeline ends up being a hot mess and there's very little that can be done to organize it. Grouping timeline features tend to make it even less intelligible and reduces visibility.
Browser at least is organized into neat categories, you can parts up and down and more or less keep it readeable.
Message 3 of 24
TrippyLighting
I would say No!
The only reason to have a timeline that records assembly joints is for position based modeling, which cannot be done with a design with only external componets.
You would have to change the Assembly design to a Hybrid design and make sure to only create internal components for organizational purposes due to the lack of folders.
That should not be a problem and you can still work without a timeline (in the Assembly/Hybrid design) enjoying the collaboration features.
In general I would dissuade the Fusions team to implement folders as they are too one-dimensional. User definable tags and appropriate sort and filter functions would be much more appropriate to organize parts/componets.
Message 4 of 24
mrm1018
I'm a Solidworks user in my day job, so I don't think I'll ever warm up to the idea of internal components...although SW does allow for internal components too.  Anyway, for that reason, I'll just leave the component tree as is - full of external components.
Speaking of my day job, our work flow is to always utilize a "fastener" folder in SW.  It makes the assembly model tree pretty tidy, especially when you have 100s of rivets and screws.
Message 5 of 24
TrippyLighting
I have used SW for work since 1998. We use Folders as well, and while it works, I still find it one-dimensional and sometimes limiting.
Message 6 of 24
mrm1018
We've just never experienced that.  Given the assemblies we create have no modifying features, like you might for a weldment, it's not limiting whatsoever.  We keep the folders at the bottom of the model tree.
Message 7 of 24
TrippyLighting
Well,  in SW you can do that, but in Fusion we don't really have folders for that purpose, so you have to create a component group. But then you cannot keep that component group at the bottom of the browser where it is easy to find. The limitation in Fusion is the browser, which lists objects in the order they are created by the features in the timeline.
A folder would possibly be timeline independent, so that would be helpful.
Message 8 of 24
aleksei_ovsienko
The very fact that I can't have modifying features in assemblies drives me up the wall. It's as if you had a car where you can't turn left and have to do a  full right turn every time you need to go left.
Message 9 of 24
clinton_buttnor8VEQX
Observer
Observer
What do you mean by one dimensional? I use folders in SW all the time. I also use tons of fasteners etc. It cleans up the tree and makes it manageable.
Message 10 of 24
TrippyLighting
You can put a part (or file) only in one folder. However, you can assign multiple tags to a file.
Message 11 of 24
mrm1018
Not sure what you mean, I have the same part in root model tree, as well as in (2) different folders.  What do you mean by tags?
Message 12 of 24
TrippyLighting
I know how this is done in SW. However, that cannot currently be done in Fusion.
The concept of a tag in CAD is similar to the concept of a hash tag in social media and can/should work across folders. macOS has implemented that for files and in Notes.
It would make finding stuff in complex designs in the browser, or timeline much faster.
Message 13 of 24
mrm1018
You lost me, dude.
Message 14 of 24
TrippyLighting
@mrm1018 wrote:
You lost me, dude.
In my day-job I have used Fusion for many years to develop concepts for manufacturing automation systems. In SW I frequently navigate designs with 10000 - 30000 parts.
Concepts usually don't need the level of detail of full production designs so I simplify e.g. remove screw, nuts, washers etc.
Still this is a component count of a current project in Fusion:
Trying to categorize and find stuff can be tedious and time consuming in such a design.
Tags would allow another level of managing complexity on top of, or parallel to folders.
Message 15 of 24
Observer
Observer
Oh i see. Yes tags help that way.
My position:
Yes tags
Yes folders
NO history timeline for non-hybrid assembly
Message 16 of 24
mrm1018
If you're navigating designs with that many components, you should be using more subassemblies.
Message 17 of 24
TrippyLighting
If you were working in such a larger assembly, you would quickly realize that a browser hierarchy (Fusion) or feature tree)SolidWorks) only gets you so far.
Of course, I use a hierarchical design structure with assemblies, sub-assemblies, sub-sub-assemblies, etc. I heavily use the Configurations feature set to manage "content".
Yet, still I need more functionality to manage complexity 😉
Message 18 of 24
mrm1018
I think you're making some assumptions about the sizes of assemblies I work on with my team.  When managing the number of components becomes difficult, it almost always points to an overly flat assembly structure.
Message 19 of 24
TrippyLighting
Managing the number of components isn't the issue 😉
Managing complexity is the issue, and a hierarchical design is only one way to do so. Tags (and folders) provide a means to quickly extract information from a design that would otherwise require a user to tediously navigate through a tree-like data structure.
If I can come up with a good practical example, I will post it here. Unfortunately, all of my professional work that would serve as a good example is under an NDA, which makes it difficult to explain what I am looking for.
Message 20 of 24
aleksei_ovsienko
I can only add that subassemblies in my opinion should not be used for the sole purpose of data organization. The way I see it a subassembly should reflect the actual build reailty. The way I think about it - if I can build it, QC it and put it in storage prior to main product build then it should be a subassembly in prototype builds and it must be a subassembly in production builds. Otherwise I would not create CAD subassemblies just to manage data and would prefer other tools.
