Announcements
Aligning points on 3D
Felipe.G
Felipe.G
Hi, I have this model that i'm working on and would like to ask for help to figure how to align this points on 3D, possibly find a better way to do it, I can think of using a plane have the reference there but if there is something easier will be much appreciated
Thank you
Mike.Grau
Hi @Felipe.G,
Thank you for sharing the pictures. These are really helpful.
I have tested a couple things and I think your initial idea with the plane might works in the best way.
You would probably do the following:
1. Create a plane in the same position as drawn in the screenshot
2. Just to check, I assume that symmetry has been applied
3. Right-click on the "Control Point" and an select "Move" and move it manually as close as possible to the plane to check how the curvature changes
4. In the active "Move" feature, select "Transform"
5. Select the "Control Point" and then select the "Direction Arrow" in which the control point moves and select the "Plane", click Ok
I hope this helps.
Felipe.G
Thank you for your help this should work fine, will report if any doubts
cheers!
Mike.Grau
Hi @Felipe.G,
Thanks for the update.
I´m glad that I could help you.
Please, keep us updated. It would be cool if you could share some nice renderings from your project.
