Align command misaligns component by 90 degrees
wrewing001
wrewing001
This NooB brought a beam component into a subassy component.
I tried the Align command to align it to a construction plane.
The wrong face (the end instead of the side) of the beam was aligned.
The Align command did not let me select just a face of the beam component.  The flip option does not fix things.
For various reasons, my beam component consists of hundreds of bodies.  I want them to remain separate for now.  Therefore, aligning just the main body in my beam is out of the question.
It looks like I like might be able to fix things with a 90 degree rotate, but that seems awkward.
How should I proceed?
  Rotate?
  Create another construction plane that is normal to the one I wish to use?
  Can I specify more than one plane and hope F360 figures it out?
  Use joints?
Is there some way to predict which face F360 is going to use when aligning a component?
Until the above issue, absolutely every dimension was parameterized.  I eyeballed things and got within 0.01 mm of perfect alignment, but the design would break if I changed certain parameters which is unacceptable.  The Align command seems bereft of options compared with other commands and I wish it were more robust.
Steven_Gao
It's a little hard for us to understand the problem. Can you help to share the dataset(or a simple example) for some investigation?
Steven
rushabhthakkar_910
A Screencast video and your Model exported in .f3d format would be helpful to see how you are moving ahead and where the issue could be..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
wrewing001
Thanks for the replies.
Since the Align command has no options other than Flip, I ended up experimentally making sure that my component was in the right orientation before I used Copy and then Paste or Paste New  to put it into the parent assembly component, after which I aligned it with a construction plane.
A detailed explanation of my work flow can hardly be a good use of anyone's time.  Look at the Align command and ask yourself how you could have a variety of alignments.  You can Flip, and that's it.
davebYYPCU
If you are pasting Components, Align is not the right tool, because it only has a flip control.
Perhaps you may have a better experience to Joint the Components where needed.
Might help....
aliobidi
Hi ,
use right tool for right issue, that's it .
or attach your file with more explain like " PIC , Screencast .. etc " to get good help
