Advanced Joints question
fredrik.hjarpeEHNYH
fredrik.hjarpeEHNYH
Hi
I have several external components in a Compilation. The main design is named by Center Base Compilation. The project is to build a B737TQ width ServoCity mechanical parts 🙂
The main design has a joint with motion so it is posable to rotate the the highlighted part in it´s position.
I have the external component Throttle Lever 1 Compilation. The design also has a Motion Joint as in the pic:
The last external components is Throttle Lever 1 - Rev Arm Mechanical. It also has a motion Joint whish will just rotate the End brick as:
If not the End brick will rotate and that´s not what I want!
A video bellow to show what my goal is 🙂
Best regards Fredrik
Accepted solutions (3)
jhackney1972
The Forum users will need you model to try and help you with your request.  Please attach it.  Open your model, select the File menu, then Export and save to your gars drive.  Attach the file to a reply post using the attachment section.
John Hackney, Retired
fredrik.hjarpeEHNYH
Hi
First thank´s for you quick reply 🙂
I tried to attached as the main design name in a
jhackney1972
Since the upper Revolve Joint is connected to the main arm, which is also on a Revolve Joint, there is no way to prevent the upper joint from rotation unless you Lock it temporarily.  The Video will explain.
(view in My Videos)
fredrik.hjarpeEHNYH
Thank you, I have find a way forward 🙂
