Adjusting thread size
jake.nicholson6VZ9D
jake.nicholson6VZ9D
When I create a thread on a small screw it looks way too big, is there any way to adjust the thread size to match the screw diameter?
etfrench
Check the Modeled checkbox in the Thread dialog to see an accurate model of the screw.  You can verify by downloading the same screw from McMaster-Carr or other manufacturer as well as using the Measure tool.
ETFrench
