Adjust Origin for whole model?
jfhext
jfhext
I recently did a bunch of modeling in which almost all my profiles are in the YZ-plane. Because of gimbal-lock problems, that makes it hard to look at the model with Y pointing up on the screen, and me adjusting the view direction in the ZW plane. Clicking on the oriented-view cube in the upper right helps -- an edge click gets me near a view that I like, but then I cannot easily rotate around z.
Is there a way to re-orient an entire model so that all those sketches I made in the YZ plane become sketches in the XZ plane? (I know I can do something like this during Manufacturing, but I'd like to reset things in the Design space!)
Here's a typical 'almost OK' view.
jhackney1972
If you want to change the sketch plane of a "Sketch" in the Model Workspace, the Redefine Sketch Plane command is what you want.  You can select a new origin plane or another created construction plane of your choice.  Be cautious, if you do this early in the timeline before a lot of other features, you could cause a problem.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
davebYYPCU
For the sketches in the top section of the browser, you are stuck with Reorientate sketch plane, (unstable) or copy paste to a new sketch on the required plane.
Usually better to start over.
For the component articles, rotate the component 90 degrees.
Might help…
jfhext
This gave me the nudge I needed, which was that I could make the main line for my construction run along the Z axis, with construction planes perpendicular to that, and move my components onto those planes --- much easier view manipulation now!
