Adding sheets to assembly drawing
denis84CYC
denis84CYC
I have an assembly drawing with several components identified by balloons on the main sheet. The second sheet has the table showing the parts list. Now I want to add dimensional drawings of each component on several subsequent sheets, with one sheet per component. Is it necessary to build joints in the main design first? Also, is there a way to easily generate an exploded view?
jhackney1972
You asked two questions and I answered them both in my Screencast.  I used a Screencast mainly to show the steps in the easy creation of an exploded view drawing.
John Hackney, Retired
denis84CYC
Thank you so much Sir! you have saved me a lot of precious time!
aravindYQXDB
Observer
Observer
If I want to create part drawings for each of the components in the assembly, and I want the part name and part number of that specific component to show up in the drawing title block, how can I do that?
Thank you,
Aravind
