I am trying to use Fusion 360 for some acoustic guitar components. To learn I started by modelling the components of a guitar in Fusion 360, and kept it so that I could update the parameters and change dimensions etc. However, as I am new to Fusion 360, to keep things simple I kept the top and back of the guitar flat, when, in reality they are curved. This is the step I need help with.
I may well be wrong with this, but the approach I’m imagining is:
- Sketch guitar outline
- Push/Pull to create body (up to this point it’s the same for a flat top)
- At a defined distance from the top of the guitar (e.g. 325mm) and along the centreline, pull the guitar top upwards (without changing the thickness of the body) to add a curve to the body in both the up-down and side-side direction.
Using the Conical Curve tool, and then intersecting this with the guitar top body I have created a parametrically controlled curve but only in the up-down direction. I have exaggerated the curve for the purpose of the screenshot below, but as you can see I also need to control the curve in the side-side direction. Essentially all the edges of the guitar body must remain on the same plane.
I don’t want to actually make the top/soundboard using CNC. However, it is vital to get it modelled correctly so that other components (e.g. braces, slipper of the neck) that I do wish to CNC will be made accurately.
