Adding fin to a pipe
capucine_lasserre2001
Message 1 of 27
Hi evryone,
I would like to model an heat exchanger with fin (you can find below a reference picture of what I would like to achive), but I have no idea of how to it.
I have already design the pipe that flows into my heat exchanger,
so I need to add the fin. Is there a smart way that I could do that ? The simpler, the better since I'm extremely new to CAO!
Thanks in advance for the help!
Replies (26)
Message 2 of 27
davebYYPCU
Are the circular fins, done as a series of round plates, or a spiral coil?
Are they fitted to just the long Pipes, and not to the joiners?
Message 3 of 27
TheCADWhisperer
tube_geometrie.png .
Will the pipe really be welded pieces as you have shown in your picture or will it be bent return corners?  Why do you need modeled fins (would cosmetic representation suffice)?
Message 4 of 27
Warmingup1953
Will it simply be decorative?
Message 5 of 27
jeffescott
Check out create coil
Message 6 of 27
TheCADWhisperer
@jeffescott
Can you Attach example solution using Coil?
Message 7 of 27
jeffescott
Message 8 of 27
TheCADWhisperer
@jeffescott
Let me be more specific - can you Attach a *.f3d file demonstrating the use of Coil feature as a solution to the design issue posed by @capucine_lasserre2001
Message 9 of 27
jeffescott
yup
If you select the end face you can modify the profile with a sketch
not going to post f3d  cause I don't want to leave him with my bad habits....thats for experts only
Message 10 of 27
no, this model will be used in CFD, and the fins are here to disturb the flow around the pipe !
Message 11 of 27
TheCADWhisperer
Message 12 of 27
@TheCADWhisperer here you have it !
Message 13 of 27
Hi, @TheCADWhisperer the pipe would be welded I think, but to be honest I have no idea since the goal is to model the flow via computational flow dynamics and not actually build it...
Message 14 of 27
TheCADWhisperer
Do you really want the flow inside the pipe to hit sharp corners?
Message 15 of 27
no the fins are for a fluids that flows outside of the pipe. And also the geometry of the fins does not need to be really similar to the photos, it is just the general idea that matters.
Message 16 of 27
Warmingup1953
I previously posted a screen capture of my rough try is that of interest to you as a Fusion 360 file?... It is pretty rudimentary.
Message 17 of 27
TheCADWhisperer
My question isn't about the fins - I haven't got that far.
My question is about the sharp angle paths.  I do not recall ever seen anything like that in the real world at that size.
Do you have a picture of something similar from the real world?
Message 18 of 27
Sorry I didn't understood the question,
the sharp angle are here just because I haven't found another way to liks pipe that are not on the same heigth, so no it's not something important in the geometry just a consequence of how I use CAO.
Message 19 of 27
TheCADWhisperer
...so no it's not something important in the geometry
I would expect it to be critically important to the analysis.
Do you have a picture of something similar from the real world - or is this a novel design of a type never before seen by man, woman or beast?
Message 20 of 27
jeffescott
Here is my way took 15 mins  needed a fit point spline rail.
