Adding Face to Form
Adding Face to Form
et_cetera
Adding Face to Form
et_cetera
Hi all,
I just got started learning how T-splines work and I'm not sure what keywords to search/resources to use for help. My model has an open front (screenshot 1) and I would like to close it like what is seen in the second screenshot. How would I go about doing this? And if you have any tips/resources I can refer to in the future, please share!
Cheers.
TrippyLighting
Please share your model (export as a .f3d file and attach to a post).
Here are my T-spline guidelines for beginners:
1. Model 80% in box view mode. The shape should somewhat resemble the desired, smooth end result. Make small adjustments in smooth-view mode. Check back in box view mode to make sure the model still has integrity. Faces should not intersect in box view mode!
2. Do not add detail until you are 100% satisfied with the overall shape and proportions of the shape. The more detail you add the more geometry you have to manipulate, usually resulting in a lot more work than necessary.
3. Avoid triangles at all cost until you are at least at an intermediate level with T-Spline modeling. Triangles are best avoided altogether.
4. Limit the use of N-gons (polygons with more than 4 edges/vertices) to the bare minimum. No N-gons with more than 5 edges vertices.
5. Start with as little geometry as you can get away with. Add more as needed. If you find that you need to stretch polygons too much to get a desired smooth shape, then you need more edge loops/polygons.
6. Don't use creasing until the very end of modeling. The key her is to avoid further modeling after creasing. If you want to see how something looks with creasing, un-crease it before continuing to model.
et_cetera
Hi TrippyLighting,
Thanks for the tips. Sorry, I forgot to upload my model! What led to this question is that I accidentally deleted the front tip of the model. I can simply undo it, but I wondered if there is any way to patch the hole in a situation where I can't undo. Thoughts?
TrippyLighting
The bridge command is what I use in this case:
(view in My Videos)
et_cetera
Thanks so much, it worked! Last question: when doing operations like this, how do I know which vertices to weld?
adam.helps
Partly you know from how bridge works—it makes a “bridge” of faces between the selected edges. All of the vertices to the side are not attached. They are the ones that need welding.
Your other hint comes from the thick outline along certain edges. Creased edges are drawn with a thicker line, and border edges are always creased. After welding, the crease disappears, so you know you’ve done it right when the edges become thin.
There are other ways to do this, depending on your needs. You could append faces (which gives more control), or you could use the “fill hole” command (less control but very fast). After appending faces you could insert points to fix any topology mistakes. Extruding the boundary edges and then welding would also work. You could also build a separate T-spline plane, move it into position, and then weld verts to combine the surfaces (this could behave strangely with symmetry, though).
et_cetera
Thanks so much all! Great advice.
