Adding Details to a Curved Surface
ianhughes7UFVF
ianhughes7UFVF
Hi
I am in the process of reproducing a Radar dish for a model that is missing the original part.
I created the dish in fusion making a side on sketch and revolved it to get the basic shapes:
There are the obalong details on the inside of the dish, that I want to create next. I realize that I could create the pattern once and then use the pattern tool to multiply it around the surface, but its how to create the pattern?
Do I create a flat sketch and extrude it onto the dish and cut the curve into it? I am not sure how to do that properly.
Any advice will be great.
Kind Regards
Ian
HughesTooling
Use a flat sketch then extrude using the From Object option or if you want a cavity under Extent use the To Object option.
Mark
Mark Hughes
Owner, Hughes Tooling
ianhughes7UFVF
Hi
Thank for that, thats very clear.
I have not used the extrude from the body before, so that will help with a lot of projects.
Regards
Ian
