Adding color library
matylda.polak
Observer Observer
Message 1 of 8
matylda.polak
Observer
Observer
Hi there!
How can I add a color library in rendering/appearance section?
Thanks for help!
Matylda
Replies (7)
Message 2 of 8
jhackney1972
The Appearance Library that is used in the Design Environment is also available in the Animation Environment.  In the Screencast I show you the process of creating a new Appearance Library.
John Hackney, Retired
Message 3 of 8
shahriarsifat1802164
There is an appearance tool that exist on rendering workspace or you can type "A" from the keyboard
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 4 of 8
matylda.polak
Observer
Observer
hi!
thank You so much for help!
Things You have showed me are new for me - thanks for that!
I will try to specify my problem better:
in the appearance, You can see the symbol of panton libraries.
I have some colors chosen, I know the sRGB numbers and NCS values.
I wonder if I can create a library with my own colors? Like the Pantone one?
I have also .acb file and .xml file palette.
I saw people adding somehow RAL library, but I don't know how.
Thanks!!
Message 5 of 8
jhackney1972
I know how to add appearances one by one to a new library but I am afraid I do not know how to import external color files, even if it is possible.  I will leave you to someone else's expertise.
Message 6 of 8
vladimir_michl
You can add your appearance libraries manually. Sam Hocking has created libraries with RAL colors, NCS colors, BS colours, DIN 6164 colors and other. Extract these .txt files or your .txt library files to the 'PantoneColors' folder on your disk drive:
C:\Users\[username]\AppData\Local\Autodesk\Common\Material Library\20081401\slib\resource\PantoneColors
See more info in the tip:
https://www.cadforum.cz/cadforum_en/ral-color-library-palette-for-fusion-360-tip12833
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 7 of 8
matylda.polak
Observer
Observer
thanks! I will try to follow Your advice!
Message 8 of 8
Hi, If you learn something new and solve your problem please give it a solution.
Thank you.
RUET
Thank you.
