Adding adhesion force between two parts
How do I add adhesive bond of 50kN force on the interface between this rubber bush and metal pin ? Can someone give me a guidance please ?
ayedurand
I would put a very thin (sacrificial-like) layer (component) between the two parts and then say that the ultimate strength of the material to whatever is necessary for the area x pressure is to get to your break away load.
I'll bet that there are artifacts due to a very thin mesh layer but play around with the thickness and the mesh density to get something you like.
my $0.02
