Adding a Material to the library
Can anyone tell me how to add a material to the fusion library please, specifically PLA as we use this a lot in our 3D printers.
thanks
matt
Can you not duplicate a similar Material and then Add to Favourites?
Possibly, however I was hoping that Autodesk would have this material set up as there is good integration with 3D printing built in. Can you recommend a good source for obtaining the specific properties required for setting one up. I can't find a web site that lists the material properties required to make the adjustments.
philrydin-orwin
Hi I am trying to do this by Duplicating, you edit everything and it all looks good, but then you cannot click OK. I have tried on both Windows and OSX platforms.
philrydin-orwin
Having super expensive HP 3D material and then failing to add PLA ASA PTEG PC
Nylon etc is crazy!
