Adding a grid pattern on faces
florent5V95X
Message 1 of 9
florent5V95X
Hi !
I've not been there for a long time. Usually, I found answers with videos, tutorials ans this forum !
But now, I don't manage to do something.
The component you see in attachement is a car inside light (old friend car, a Facel Vega 😉 ). I'll have to print it in 3D with translucent plastic.
This component is 99% finished. But, I have to add a grid pattern inside it (internal faces you can see on the picture). The grid is made with 1.1mm squares, spaced at 0.4mm.
I can't find an easy and aesthetic way to do it.....
Thanks for any help ! 🙂
Replies (8)
Message 2 of 9
etfrench
I'd start by:
  1. Modeling one square in the upper corner of one of the long rectangular sides.
  2. Create a rectangular pattern using this as the base to fill that side.
  3. For each horizontal row, create a path on a curved end.  Split body or intersect may be useful here.
  4. Fill the end using a pattern on path.
  5. Mirror the side and end to complete the model.
Note: Don't use sketch patterns for this.
p.s. Use dimensions to accurately place the first square.
ETFrench
Message 3 of 9
florent5V95X
I don't manage to do it.... I tried as you said, just on flat sides, to start. But each time I create the sketched pattern (even with bodies, as you said no to do !) my computer dies... (core i3, 16gb ram, 4gb nvidia video card, 256gb ssd).
I don't figure out why...
Message 4 of 9
etfrench
Attach your file to the thread (File|Export|Archive file *.f3d) and someone can provide help.
ETFrench
Message 5 of 9
florent5V95X
Here it is !
https://we.tl/t-Q3ioXJMAqq
I didn't want to ask too much....
Message 6 of 9
etfrench
I don't know what that link is.  There is an option to attach files to each forum post.  Please use that.
ETFrench
Message 7 of 9
florent5V95X
This is a wetransfert link.
I tried to attach the file inside the forum but it crashes my firefox...
I try again, in this answer.... and.... it works !!!!!
Message 8 of 9
etfrench
Here's one way to create the cubes on the ends:
Notes:
You can use the first midplane to mirror the rectangular blocks.
Create another midplane at 90 degrees to the first in order to mirror the end blocks.
I randomly picked the number of degrees for the circular patterns.  As you can see they're not quite even.  If you suppress the end blocks in each of the circular patterns, you can create the end blocks with a separate circular pattern.
ETFrench
Message 9 of 9
florent5V95X
Thanks a lot, so much !!!!!
I am now able to do it. Your explanation and video are clear ! The thing is done 😉
Incredible how learning is so fast when you have help from patient people !
