adding a different material under Simulation / Study Material ??
Joey68tc
Joey68tc
I am certainly no expert, so I need to ask, how does one add a different material under Simulation / Materials / Study Material ??  I have steel, which I assume is a default.  Just want to add aluminum 6061.
Under Manage Physical Materials I see many materials, but cant seem to add to Document Materials.
Thnx for your guidance.
Tom in VA
TheCADWhisperer
Either change in the Design workspace
or
override the Design material with your desired Study Material.
You can copy studies changing only Study Materials for comparison.
Click on the Same as Model to override to a different material as desired.
If you need to add a material not already in the Library - that is a different process, but you state Aluminum 6061 which is in the library...
Joey68tc
Thnx CadW, let me give this a try...
