Adding a Bulkhead to a Shelled Body
kevinwatts
kevinwatts
I have constructed an irregular profiled Shelled Body. See attached simplified sample of starting point. In Fusion I am working in Model Mode.
I need to add bulkhead inside, at a specified elevation, that will Join with the shelled body walls. Using an Offset Plane, I can set the desired elevation.
I am sure that it is simple but I need some help. How can I construct the bulkhead?
Kevin
martin.zatecka
I have an idea, I would use web, it is simple way. Please look at the attache video. Does it what you need?
regards
Martin
Martin Zatecka
UX Designer
kevinwatts
Thank you Martin. I will be using the method you show today. However, I was able to take another approach that I will have to add with notes for others later.
martin.zatecka
Hello Kevin,
I like Fusion, because it offers many various ways how to approach the goal. Please share with us your experience, it is great you found your way. I'm looking forward to it.
Martin
Martin Zatecka
UX Designer
