I'd like to add the weight of each part to a BOM table. How can I do this?
Also, will the weight automatically update in the table if an iteration in the design is made?
Kind regards,
-Dan
Solved by g-andresen. Go to Solution.
try this:
If something is changed in the design, the drawing can be updated to the new value.
günther
Hi @g-andresen ,
Thank you for your help!
When placing a part list, I don't see those options, and after placing the part list, I can't seem to find a way to edit the columns. Could you please tell me how you opened those options, or how I can edit the columns of an existing part list?
Kind regards.
