Add a Web or Wing gusset?
I was challenged by a friend to see if I could make a set of handlebars for a motorcycle that has a web or a wing design gusset. Since there is a bit of a organic bend to the bars I can't figure out how to approach this?ConceptConceptScreenshot 2018-10-11 17.28.25.pngTop viewTop viewFront viewFront view
I'm a bit stuck here.
mavigogun
You might first create a surface supporting the webbing and dividing the bar longitudinal profile (Sculpt) and Project Sketch (sp)Lines to that Face (or Split Face)- Piping the product will center the surface on the Pipe, leaving you a centered surface to build the webbing on.     Just one way.
sanket223.patil
Can you share the model ? I can give a try
Sanket Patil
Mechanical Engineering
Expert Elite
jeff_strater
here is one way to do it, using Rib, which is really designed for just this kind of thing.  My approach in the video is not very precise, but hopefully it will give you some pointers on how to do it.
Jeff Strater
Engineering Director
Interesting. I may not have as much knowledge of Fusion as needed to follow these instructions?  I think I do
understand most of what you mean though?  Thank you for taking the time to respond.
Thank you for taking the time to respond! And thank you so much for this screencast! For me it made it much more understandable to follow as I am still pretty new to Fusion. That 'Plane through 3 points' is a cool idea. I might have a bit more curvature in the horizontal section of my bars than you do on your sample? I can't wait to give this a go tomorrow after work!
Again, I really appreciate you taking the time to help!  😉
