Adapting a relief onto a rolling pin
donaldo3
donaldo3
I am using a 3D scanner to model z-adapted reliefs the fast way. The reliefs are about 5mm high How can I adapt, deform, roll these reliefs up onto a rolling pin which I would like to 3D print? Please get me right, I do not only want to bake sweets which have the outline of a certain object, I want to bake small reliefs. I did a lot of trials but, they are far away from what we would expect 😉 tasty 😉 they are but... - don
innovatenate
Autodesk Support
Autodesk Support
Can you share some screenshots of what you're trying to do?
It sounds like you're looking for a deform tool like a bend or twist, like this:
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/bend-body/idi-p/5291287
There's not currently a feature that does this, but you can add your support by voting up the idea in the Ideastation.
The only other thing I can think is something along these lines using the sketch project to surface tool.
https://www.youtube.com/watch?v=WEdbBTQ0qaw
I hope these help. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
donaldo3
Yes, oh yes this helps me, thank you very much, your help and advice are
welcome. don
