accurate countersinks and counterbores after press pull
soliloqueenwastaken
soliloqueenwastaken
Right now, if you have a countersunk or counterbored hole, and you pull the face upwards, it extends the counterbore or counterface upwards. This is expected behavior and is, for my application, correct. However, it does NOT update the automatically generated counterbore depths or countersink diameters in the 2D drawing, which it probably should
kacper.suchomski
Hi
Automatic dimensions read parameter values, not geometric distances.
Kacper Suchomski
soliloqueenwastaken
yes, but should they
kacper.suchomski
This is how they work and you should adapt your workflow to it.
Kacper Suchomski
soliloqueenwastaken
I regularly need to change the amount of extra stock on each side of a part depending on the specific machine a contract lapper is using and it's annoying to go through and change all of them manually. Is it reasonable for the software to automatically generate factually incorrect drawings? I understand that the easiest way to program the software is to read the parameters, but I would appreciate some extra effort here.
kacper.suchomski
Automatic dimensions are a nice addition to standard design scenarios.
Kacper Suchomski
soliloqueenwastaken
don't disagree with you, I just don't think it's reasonable to the end user that they should soft fail to incorrect dimensions with no warning, no disclaimer and no way to tell at a glance if they're wrong. it makes hunting through multi page drawings to solve all these little errors a bit of a chore.
