Account Access
Account Access
Account Access
I have been unable to add users in the manage.autodesk.com page.
Can someone assist me in getting this resolved?
Thanks!
brianrepp
@Anonymous are you currently the account administrator?  If so, this article should help guide you through the process:  https://knowledge.autodesk.com/customer-service/account-management/subscription-management/users-permissions/add-remove
Let me know if that helps!
I should be. I created the account.
When I try to add a user, the user does not show up in the window.
Erik D Arendall
Research, Development, & Testing Manager
matthew.d
Hi @Anonymous,
Your contract appeared to start at a later date. I have gone through a resynced your account. This can take up to 24 hours to fully take affect (usually much less, right now about 10-15 minutes). You should be able to use everything when this has taken affect.
Edit: Just did a check in and it looks like your account is now working as expected.
Please hit the Accept as Solution button if my post resolves your issue.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
