Accidentally moving objects without selecting move
timF4ETD
Message 1 of 15
timF4ETD
I select any part of an object/component and move it, without selecting "move" transform. Even if there is a joint.
What I mean is, I click and hold on the object (face, edge or vertices) and move it around in space.
This gets annoying as I can accidentally change the objects location and dont realize it.
Is there a way to disable this, without completely disabling selection, as I still need to select it.
Replies (14)
Message 2 of 15
laughingcreek
your just doing a temporary move of a component. hit revert in the upper right and everything goes back to their position-
you can also ground a component (rightclick component in the tree and select ground)
Message 3 of 15
timF4ETD
Thanks! However, sometimes I dont notice I moved it. And the reverting function disappears, and there's nothing captured in the history.
Ground options works nice
Message 4 of 15
TheCADWhisperer
This gets annoying as I can accidentally change the objects location ...
Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Message 5 of 15
timF4ETD
All of my files are like this. I think it has to do with settings.
Message 6 of 15
TheCADWhisperer
Can you File>Export a *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Since all of them have this behavior - any one of them will do for the experiment.
Ground?
Rigid Group?
Appropriate Joints?
Where did you go?
Message 7 of 15
timF4ETD
Attached
Message 8 of 15
timF4ETD
Ground seems to be working, but joints and rigid group dont work.
Message 9 of 15
jeff_strater
this design only contains one component.  When you say "joints and rigid group dont work", could you explain a bit more what you mean?  What are you creating joints or rigid groups to in this design?  Perhaps a screencast will help illustrate the problem.
Jeff Strater
Engineering Director
Message 10 of 15
timF4ETD
For example, if I made a joint between 2 bodies. They are fixed together, however if I click and hold the face on either component, I can move them in space. This changes the position relative to other components.
However the problem isnt necessarily making joints. Even without a joint, I can move components around in space, without hitting "move".
The current solution is grounding all of the components.
Message 11 of 15
TheCADWhisperer
Let's try again. Post a file that actually exhibits the behavior. I think you are missing a critical concept of how Fusion 360 works and if I am correct - it will be easy to demonstrate with your actual file.  But it has to be a file that illustrates the actual behavior.
Message 12 of 15
timF4ETD
Is there a way to disable this kind of movement
Message 13 of 15
jeff_strater
Yes and no.  There is no way to disable component drag in a parametric design.  This is an intentional capability that exists so that you can exercise a system of joints between components. You can prevent it from having an undesirable effect by fully constraining your design.  You have found one way to do that:  Grounding everything.  This works, but it is restrictive, in that then the components won't move even if you want them to (for instance, if you want to create a joint between two of them after creation/insert).  You can also create a system of joints that fully defines the position of all the components in your system.  If your entire design is rigid, creating rigid joints, or rigid groups among all the components, with one of them grounded, also achieves the same effect.
Jeff Strater
Message 14 of 15
chrisplyler
1. You cannot make Joints between bodies. They are made between Components.
2. Typically, we Ground one Component. We pick a Component that we can consider a "base" that doesn't need to move.
3. Then we Joint another Component to that base Component. Then we Joint a third Component to that base Component, OR to the second Component that was previously Jointed.
4. Etc., etc., etc.
5. In this way, due to the first Ground, and subsequent Joints, EVERYTHING gets defined in space relative to something else.
Message 15 of 15
mathewskuria
It is annoying when objects move when we don't want them to move.
This is because of the "Component Drag" option.
To disable it, go to Select Menu and untick Component Drag. That's it.
