Abort Computation Feature Request
grahambotleighton
Message 1 of 10
grahambotleighton
I was wondering if there is a way to abort a computation (with the spinning beach ball symbol on my Mac) while it is happening. Often times, I will mistype and hit enter while doing something, and Fusion will take like half an hour to compute it. Many times I am forced to quit the app and risk losing my progress. Even if it does compute after a while, I then have to undo the mistake, which takes another half hour to compute. And after all of that, I'm right back where I started, but an hour behind. I have seen this on a forum before, but the most recent post on that was in 2019. So I am proposing a keyboard shortcut that will stop the computation dead in its tracks. Some people have recommended that Fusion predicts how long something will take, but that seems pretty useless. I think the decision should come down to the user. Thank you for your time!
Replies (9)
Message 2 of 10
Radwan-Almsora
Autodesk Fusion does not currently have a dedicated kill-switch shortcut for general 3D computations. For mistyped parameters, some operations like CAM toolpath calculations can be stopped using Ctrl + G. Otherwise, you must force quit via Command + Option + Escape or cancel via the Autodesk Fusion Support Forum.
To resolve your issue, you can enter here.
How to stop toolpath calculation in Fusion 360
Spoiler
If you would like to join the unofficial "AutoCAD & Autodesk Experts" Telegram group, we help users who use AutoCAD products. The group is new, and here is the link if you are interested: https://t.me/+Qhrck8woBvVhMzQ0
Spoiler
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 10
grahambotleighton
Yeah that's the issue. I'm saying that this feature should be created. Hopefully I'm in the right place posting this, never used Autodesk forums before.
Message 4 of 10
Radwan-Almsora
Message 5 of 10
grahambotleighton
I think I'm in the wrong spot. Where do I go to request new features in Fusion?
Message 6 of 10
Radwan-Almsora
Message 7 of 10
TrippyLighting
This is the right spot!
This has been requested many, many times and is definitely on the Fusion team's radar!
Message 8 of 10
Drewpan
I agree we need a Computation Abort method.
You say that you are getting these frequent long computes when you accidentally
hit the button? This may also be a workflow issue. There are a number of workflows
and techniques that this forum recommends people avoid to cut down on this kind
of thing. They start with fully defined Sketches because a sketch that is not fully
defined can cause fusion to sometimes "guess" at design intent and this can cause
this grinding behaviour. Another common problem is frequent and unnecessary
use of the Move command. This is a big no no because every time fusion sees the
move command it does a full re-calculate up to that point in the timeline before it
moves to the next item. One "might" be ok but string two or more together and
fusion does it EACH and EVERY time. This causes a major hit to performance. Many
people use the move command INSTEAD of a Joint and this is plain wrong. Two
components are NOT joined simply because they are adjacent. Also people use move
because a component is "in the way" and they cannot see to model another
component. Again this is incorrect, use the visibility feature on the Browser Tree.
There are other workflows that cause fusion to grind, these are the two main ones.
A quick re-read of the documentation can help solve some of these issues. The
embedded tutorials are excellent for learning and so is the Self Paced Learning.
Both of these are hard links within fusion so they are easy to find.
Keep on Fusioning.
Cheers
Andrew
Message 9 of 10
TrippyLighting
@Radwan-Almsora wrote:
... force quit via Command + Option + Escape or cancel via the Autodesk Fusion Support Forum.
Spoiler
That sounds like quite a hallucinatory workflow. How do you cancel Fusion's computation "via the Autodesk Fusion Support Forum" ?
Message 10 of 10
grahambotleighton
Thanks for the info! I do my best to avoid the “move” command and leave sketches undefined. Normally for me it’s just because of a ton of math (that autocorrected to meth 🤣) that Fusion struggles with. And then while it loads I think about how I could do it simpler, which I go back and do. I’ll definitely keep those tips in mind though 👍
