Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Ability to Export Component in Subassembly as DWG
0 REPLIES 0
Message 1 of 1
CMCORE
70 Views, 0 Replies
Hi- I have a feature request.
I know that we have the ability to export individual components in a design as STEP, STL, IGS, etc, but not as DWG. The only way that I've found to be able to export anything as DWG is by exporting the entire design. However, I've run into multiple situations with vendors where they require a DWG of a sheet metal component instead of a STEP file, which can only be done if-
1. I "save as" the component as a single, stand-alone design and from there export that design as a DWG (not a clean process, and creates extra design files that are not externally referenced)
2. I derive the component to a new design and repeat the process in option 1, which maintains the design with updates from the original, but again is extra design files laying around.
If the "export" of a single component allowed for DWG exports, that would be really nice!
Thanks.
Tags (3)
Labels (1)
0 REPLIES 0
