a way to export volumetric lattices as body
matheyer
matheyer
I want to export a body that has been given a volumetric lattice (Gyroid) as an SAT file. Currently, I see only one solution for this: after a body is modified with an internal lattice structure, it must first be converted to a mesh, and then the mesh can be converted using the 'faceted' method. The problem here is that the file becomes much heavier when a mesh is created, or I have to opt for a mesh with fewer elements, causing the Gyroid to lose its smoothness and develop indentations.
Additionally, I want to use this file later in Abaqus, which means I will need to mesh the exported file again. It is obviously not ideal to mesh a body twice.
Does anyone know a way to export the Gyroid structure as a smooth body?
g-andresen
I am not aware of any, nor can I imagine how such a complex structure can be created with a significantly reduced amount of data while retaining all the details.
günther
wersy
What works with Solidworks could perhaps also work with Fusion.
Is it worth the effort?
https://youtu.be/PJovx-ytJYI
TrippyLighting
@wersy yes, that is possible, but obviously does not offer the same combination of modeling speed and parametric and "fast" as the lattices in Fusion.
TrippyLighting
@g-andresen wrote:
...nor can I imagine how such a complex structure can be created with a significantly reduced amount of data while retaining all the details.
Side FX Houdini can create this as a quad mesh procedurally and parametrically, but the output might be a quad mesh instead of NURBS surfaces. Blenders geometry nodes also might allow to do this parametrically/procedurally also with the output being a quad-mesh.
That quad mesh can then be converted into ta T-Spline and NURBS. It will require manual modeling to trim it and combine it with the model of the OP.
TrippyLighting
@matheyer wrote:
Additionally, I want to use this file later in Abaqus.
Doing FEA on Gyroid or other lattice structures will require an enormous amount of computing power and memory
shubhambRKD3L
Community Visitor
Community Visitor
Here are the steps you can follow:
1. Create the desired volumetric lattice.
2. Convert the lattice to a mesh body.
3. Tessellate the mesh, which transforms it into a “body” (from the mesh menu/module).
While this method technically works, the mesh body of a lattice typically consists of numerous mesh elements, depending on the desired accuracy. I recommend a low-accuracy mesh, which generally creates between 100,000 and 1 million elements. Higher accuracy can quickly exceed a million elements. As you can imagine, tessellating that many elements can be time-consuming. However, in some cases, medium accuracy can also be achieved, depending on the complexity and size of the model.
I hope this information is helpful.
