Still rather new to F360, and especially the sheet metal approach.
I'm drawing up a firepit to be laser cut in 3mm steel.
Everything seems to be going OK so far, but I'd like the leg that I've just created to come off from the main body at an angle. At the moment its created by using a sketch of two lines at 90 degrees to each other, and I was pleased that F360 made a bent piece of metal to fit the profile using the flange tool, but I can't see a way of extruding this leg at anything other that 90 degrees from the base plate.
I'm keen to learn how to do this 'properly' - what would be the best way to do this?
Next step is to add tabs and slots to hold the legs in place while they are welded. Any tips on how to do this also appreciated!
