Hi
If you load up the attached file, Sketch144 should be selected or alone, and I've noticed there's a ghost Sketch, or I'm guessing the remains of a modified Sketch. I've tried going back through the Timeline and editing the Sketch, but I'm not able to select and delete it. I think it's causing the new one, the one that you can select, to fail at Revolving and Joining another mesh as I keep getting an error. Is there a way of removing this ghost Sketch or is it simply a case of deleting the whole thing and starting over?
