I just moved to Fusion 360 from SketchUp, and I'm finding it really difficult. I'm trying to make a car from two sketches. When I was trying to create the roof, I had the side profile and the top profile of it in my drawings. I traced the lines with splines, and I don't know how to combine them (Combine the width from the top down drawing and the height of the side on drawing if that makes any sense). My solution was to extrude one of the shapes, and then cut it by extruding the other. The problem with this is twofold, I only want a line but end up with a solid, and I don't know how to get rid of the rest of the solid that I don't need (it wont let me simply delete it). The second problem is that after extruding the traced line disappears, so when I need it again for something I need to trace a new one which won't be the same. I tried to copy the line, however the copy disappears as well when I extrude the original.
To slightly help explain what I mean I have attached the drawings with the lines I want to combine colour coded.
Thanks for any help.
