4-1 Merge Collector Not Coming Out Properly
mmicciolo
Message 1 of 23
mmicciolo
Hello All,
I am trying to create a 4-1 merge collector. I can create the individual pieces. I am using 6" long pipe, 2" diameter, 11 degree intersection angle and cutting 270 degrees off of each pipe so that 4 x 90 = 360.
The pieces come out fine, but for some reason when trying to join them together into the collector, the last one never fits correctly.
Measuring each individual piece i get 90 degrees, but when two are aligned it reads 148 instead of 180.
Im not sure what I am doing wrong? Is it just an alignment issue?
Attached is a screencast as well as an attachment of the project.
Replies (22)
Message 21 of 23
TheCADWhisperer
@kostas_kritikos wrote:
Is there a way to automatically adjust the angles of the joints so that these 2 pipe surfaces become parallel?
Yes, but it looks like you have everything as Rigid Joints.
Message 22 of 23
davebYYPCU
Build it in place, with the hardware dimensions as required.  You need a centre line path for a pipe or Sweep.
Your pot luck method is too hard.  Make Fusion do the thinking.
Might help....
Message 23 of 23
kostas_kritikos
You mean *.f3z? I already did.
