3D printed transparent tip jar with embedded "light pipe" for LEDs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all!
I'm working on a tip jar with LEDs underneath. I want to design it out of 2 bodies - one will be the shape of the jar and the other will be hollow and serve as a path for the reflected light to follow. I'll also use it as a cutting tool in the main jar body so the two don't overlap. Here is my initial concept drawing (the square is the LED in the NeoPixel ring):
I have a "core" printed that seems to work pretty well:
I'm now at the point where I need to design the sides of the jar and incorporate the light pipe body into the shape. I'm having trouble getting the loft I need:
I'm having trouble with the loft command since my starting and ending faces aren't 2d planes. In the pic above I've tried using a rectangle in an offset plane between the outer edge of the jar and the core and doing a bi-directional loft. That seems to work, but I still need to extend the shape up and down to the top and bottom of the jar.
I'm still pretty new to Fusion 360, but I'm learning fast! Can anyone give me suggestions for the best way to do this? I'm sure I'm overthinking something.
Thanks in advance!
Steve Hurd
Floyds Knobs, IN
