3d Driveable Model Constraints
Hi Everyone
Please excuse my terminology, I am new to Fusion 360 and new to CAD in general.
I am trying to make a driveable 3d model using parameters.
I manufacture stainless steel handrails for a living and I am trying to setup a base model, from which I can just enter the parameters on a per job basis to modify the drawing in order to cnc mandrel bend the tube.
Here lies my problem....
If you look at the two attached screenshots attached, you will see that when I modify the dimension circled in red, the upper section of the handrail does not all move perpendicular to the dimensions I have just changed. Rather only the end of the line attached to the one that has had the dimension changed moves.
I have spent hours playing with constraints, driven/not driven, changing my drawing workflow etc... none of which have fixed my problem. I thought a perpendicular constraint would be the solution however it will not allow me to select the two lines where this problem is occurring.
Is this associated with the drawing being 3d, is this a workflow issue, is this a constraint issue?
Any assistance would be appreciated, thank you in advance.
Dallas
