3d curve offset
3d curve offset
Message 1 of 9
3d curve offset
Hi
 I have attached my 3d model for your reference i created a 3d curve but  i couldn't offset some value  how can offset my 3d curve anyone can explain me .
Replies (8)
Message 2 of 9
jeff_strater
offset is not supported for 3D curves - it is a 2D only operation.
Jeff Strater
Engineering Director
Message 3 of 9
TrippyLighting
Not only that, but developing this in 3D space instead of using a sheet metal workflow is really needlessly complicated. Aside, of course from these splines having way too many control points.
Message 4 of 9
artemSIV
Hello. Here you can’t do without ingenuity. We can use the surface on the edge of which this 3D sketch lies. I hope I correctly understood your desire. Good luck to you.
Message 5 of 9
MichaelT_123
Hi Fellows,
Offset of 3D curve is topologically equivalent to sweep along the curve with a circular profile. The resulting shape when intersected with a body/surface will produce the respective curve's offset to created face/edge(s).
So, the operation is possible, although it is no single click one.
Regards
MichaelT
MichaelT
Message 6 of 9
Beyondforce
Hey @divakarcam ,
Maybe this workaround will help:
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 7 of 9
Hi friend
Thanks for valuable reply nice one but i want to offset radially not axially.
Regards
Divakaran. M
Message 8 of 9
TrippyLighting
@Anonymous wrote:
Hi friend
Regards
Divakaran. M
You'll have a much easier time modeling this when employing a sheet-metal based workflow. Are you familiar with that technique?
Here is the original thread explaining how that works.
This is a link to a video tutorial explaining the process.
Message 9 of 9
artemSIV
I think that my screencast already contains complete information about the process, right?
