3D Annotation
3D Annotation
Message 1 of 9
3D Annotation
Is there a 3D Annotation tool in Fusion 360?
Replies (8)
Message 2 of 9
Marco.Takx
Hi @Anonymous,
At the moment there isn't.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 9
sanket223.patil
Hello @Anonymous ,
No , but You can show sketch dimensions . Just on the visibility of sketch and right click on it and select show dimensions . It will show dimensions of sketch .
Sanket Patil
Mechanical Engineering
Expert Elite
Message 4 of 9
I second the idea of 3d text annotations.
Message 5 of 9
I 3rd the motion. Has been really annoying to not have for some visual representation needs I have. I have little hope though that this will be implemented. I feel like 2d visual representations an unfortunately neglected aspect of fusion.
Message 6 of 9
paul
We need scalable 3d annotations. This post is NOT solved.
Message 7 of 9
t_koehler
It´s the year 2023 now and i second that.
We have had the question if there is a 3D annotation feature or a way to view Inventor (.ipt) 3D annotations in Fusion360 by a couple of (prospective) customers.
I personally couldn´t find a way to make it work.
Are there any updates on this subject?
i appreciate information to this,
thanks!
Message 8 of 9
Uwe_Lindner
We need 3d annotations from Inventor Models at Fusion360.
This post is NOT solved!
Message 9 of 9
t_koehler
Since nobody seems to be interested in solving this, here is a solution:
1. create your model in inventor and add 3d-annotations to it, save the file and upload it to FusionTeam
2. open the file in Fusion
3. switch to the workspace "manufacture"
4. in the browser on the left side, toggle on the visibility of "PMI"
5. you should now be able to see your 3d annotations. be careful: in some cases they look slightly different than in inventor. the writing may be mirrored or stuff like that. i hope this will be fixed soon.
