3 Points Plane does not work (Within Mesh Workspace)
Hi All,
I just wanted to report that the 3 Points Plane (Mesh Workspace) does not work as expected.
I tried several Meshes (Topologically correct) but the final result is always the same.
https://www.youtube.com/watch?v=LxaonKaU_9Y&feature=youtu.be
Thanks in advance
lichtzeichenanlage
Really - you're adding advertisements to something you want help for. Bad move. In this forum AD's screencast is the weapon of choice. Adding ads her just makes me run away.
I did a new video.
I realized that the problem comes if I rotate the scan data (STL) in F360.
If I leave the STL as it is then the command works properly
