2mm Pitch 6mm wide belt profile
Message 1 of 26
I am making a turntable that is 6 inches in diameter. I want to use it with a 2mm pitch, 6mm wide belt like those used in 3D Printing. I am learning Fusion 360 and am not sure how to go about making a 6 inch (152mm) disc with the correct pitch profile. I would like to eventually have those parameters set up so that I can vary the diameter. Any help would be much appreciated.
I will 3D Print the 6 inch diameter disc that is 10mm wide, 4 mm for the edging to allow the belt to stay on, 6mm for the belt.
Replies (25)
Message 21 of 26
@etfrench Thanks, but that site has the spec for the belt. If I understand this thread correctly, that's not the same as the specs for the pulley. I'll poke around ont he site a bit, though, see if I can find a drawing of the actual pulley spec.
Message 22 of 26
etfrench
Attached is a file for a 20 tooth GT2-3mm pulley.  You should be able to use it to convert the GT2-2mm file to GT2-3mm.
Note: The file was created in Gearotic and the zillion short line segments haven't been converted to splines.
ETFrench
Message 23 of 26
Thanks @etfrench  , but I'm looking for a parameterized template, similar to the one attached earlier in the thread. The file you attached doesn't have any dimensions defined in it, so it's hard to turn it into a general template (although the single-tooth profile is helpful!)
Message 24 of 26
chrisplyler
@etfrench wrote:
The teeth on the pulley must have the correct profile.
Really? I looked at a GT2-2 belt, and I'm pretty sure a paddle wheel would work, as long as the blades were thin enough to fit between the belt's teeth and were 2mm apart. Or even a pulley circumference made up of 0.5mm wires spanning the face every 2mm seems like it would work just fine.
No?
Message 25 of 26
etfrench
@Anonymous The intent of the attached file was for you to compare it to the parameterized 2mm pulley, then create your own parameterized 3mm pulley file.
@chrisplyler Smiley Happy
ETFrench
Message 26 of 26
@davebYYPCU wrote:
Changed my file to be parametric, I like a challenge, and so far has not broken the file, by changing the parameter for the Circumference, about the limit of my math skills,
Looks like some recent Fusion update has broken this design. Changing the Ccfn parameter now just results in an angry sketch warning "Compute Failed." 😞
