Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
2d spline and 3d spline, difference in handles
cadTPLWJ
cadTPLWJ
If I draw a spline in a sketch, close the sketch and then move the spline in 3D off the plane the spline handles are not possible to manipulate any more. In the attached sketch, the lift spline is lifted off the construction plane.
Am I missing something?
I want a spline in 3D space that can be "rebent" in 3D space.
davebYYPCU
You can manipulate the 3d spline handles, but you can only to do so with the Move command triad,
Select the end point of the handle, then Move Command and the move triad will snap to the selected end point.
To select another end point, you follow the Move - Triad routine,
Might help...
cekuhnen
@cadTPLWJ @davebYYPCU
Not to go into details but for the moment I would also stay away from 3D sketches in general as there
are some problems with the engine that can make them easily break.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
