2D Drawings module. How to edit the length of the drawn lines
baddipl
baddipl
Hello.
So, in the latest update Autodesk included new feature called "create sketch" in the 2d drawing module. I have a problem because I would to draw by myself welding symbols but I can make it as it should be made. I can't draw a line exactly how I want because there is no way to give to the line the dimension that I want.
I would be grateful for the help. I hope there is the feature to edit the length of the drawn lines and somebody of You will help me.
g-andresen
Admittedly, it's very cumbersome, but it works.
1. create sketch on grid
2. finish sketch and dimension
3. restart sketch and move elements > dimension follow
sketch and dimension in drawing modesketch and dimension in drawing mode
günther
