2D DRAWING TEMPLATE
2D DRAWING TEMPLATE
catfishking105
2D DRAWING TEMPLATE
catfishking105
I am currently using the standard template fusion provides when making a 2D drawing within drawings from design.
I would like to change the title names of the attributes for instance the very first box "PROJECT TITLE" per the attached PDF.
I keep seeing places that suggest changing the title block but it requires using auto cad and i only have fusion to work with.
hopefully this may be  a simple thing i am overlooking, please any suggestions would be great!
MUM_dloew
have you the Inventor file of this?
Than i can quickly convert it for you.
Daniel Loew
Application Engineer
Inventor | AutoCAD / M | Vault | Fusion 360
Kudos are greatly appreciated. Everyone likes a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
catfishking105
I apologize I am very green to Fusion clearly, I have used the standard Drawing template that is provided in fusion drawing from design. However when I go to try an export the template I have saved i have limited options within fusion, short of exporting as DWG or PDF or as a drawing template. Also to note since this would be a web based program I have no actual files to select from on my pc. Short of the ones I have exported in those formats. Furthermore I do not have inventor that I know of I have only the fusion 360 program. Please forgive my ignorance to such basic things I am sure these are to you.
>> have you the Inventor file of this? Than i can quickly convert it for you. Hi - I have 2 Inventor 2017 drawing templates I'd like to import into Fusion 360. Can you help me do this? I posted a question about it here on the F360 Forums: https://forums.autodesk.com/t5/fusion-360-design-validate/import-drawing-templates-from-inventor/m-p... Thanks. Matt Slay Jordan Machine Co. Birmingham, AL USA
