2D drawing Model Space
bryan5
bryan5
Is there a model space in the 2D drawing environment in Fusion 360 to create simple 2D drawing designs?
Working in a sheet metal job shop I do create some simple 2D geometry wether it is a simple rectangle shape with a few holes, a ring to act as a spacer or a lift eye for a panel or skid. I only need to create 2D geometry which can be placed on a title block (for ISO purposes) and used for post processing at a laser/waterjet/plasma. Items like this I don't need to go fully 3D but still need to keep a record of.
A model space with simple parametric drawing features in the 2D drawing environment would be great.
Bryan Lagrange
HughesTooling
No you can't draw in the 2d drawing workspace. All you can do is draw the layout as a sketch in the model workspace then extrude into a thin body, save the design then use the design to create a new 2d drawing.
Mark
Mark Hughes
Owner, Hughes Tooling
