2 Possible bugs:Moving component, change parameters on copied components
bluelife
Message 1 of 8
bluelife
I have a file in which when I try to move any component via the manipulator and numerical input, fusion 360 either crashes or hangs and sometimes doesn't move the component at all.  Movement seems "restricted" in one particular direction more than the others. Please see the screencast.
Movement of bodies doens't bring the same results.
I have already tried in a simple file and I don't have the same problems.
Another thing is I copy a component and paste as new, try to change the parameters of the component via the spreadsheet and I can't do it. Now, if I paste as new again I can change the parameters of the newest pasted as new component via the spreadsheet.
My pc is with a 6-core amd fx cpu and a nvidia quadro 600 gpu.
Replies (7)
Message 2 of 8
TrippyLighting
Where's the screencast. Also, could you share the model ?
In general I would not recommend Quattro or Fire GL graphics cards for work with Fusion as I've explained in this thread.
Message 3 of 8
bluelife
Thought ScreenCasts where put directly, didn't think about pressing preview Smiley Indifferent
I understand about directx and professional cards in fusion 360 but I also use other software where those cards are much superior in both display and fps wise quality.
Can I send you a private message with the link TrippyLighting?
Message 4 of 8
TrippyLighting
This was hust reported also in another thread and it looks like a bug to me.
danglboom at mac dot com
Message 5 of 8
TrippyLighting
The reason you cannot move some of the parts is that you've enabled a contact set involving al components. If you delete that you'll be fine.
Using a contact set for an assembly without any moving parts is of no use, so there is not danger in deleting it.
Message 6 of 8
bluelife
Thank You,
Stupid mistake I didn't see
Message 7 of 8
doepcu
Also have the bug of not beign able to edit parameters of component copies. attaching my screencast demonstrating the problem.
Message 8 of 8
Phil.E
I just tested the fix for the problem of copied parameters and am glad to say it's fixed. I'm pushing for an early update but it may not qualify. If not, expect to see it in about a month.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
