Hi everyone!
I have two different questions that I would like to share with you to check if I'm doing something wrong.:
1. When drawing a sketch with spline, why sometimes when I scale a spline I got it deformed?
I draw cookie cutters and I need to have it in different sizes, so I create one and scale it to required sizes. But sometimes when scaling it, it deforms. One solution I use is to export my sketch as DXF and import it to the same file and then scale this DXF. It works, but sometimes I got another issue (question 2)
2. Why sometimes I can't fillet a body?
I'm using the same example as above. I draw a spline, export sketch as DXF, import it, copy imported DXF to the first sketch and then scale this 2 drawings. One DXF I can't fillet, but original spline I can. And both scaled drawings I can fillet... Please see in the picture below. Green arrows are "Filletable" and red arrow is not "filletable".
f3d file is also attached.
Thank you in advance.
Luis
